need a little help
mazzy
Anyone know what I can use to plaster the inside of the firebox with that will resist heat and not pop of in time....thanks in advance
dont know what a fire box is but had a quick google and came up with this ive never used it so wouldnt know what its like
Link Removed
its expensive tho £39.99 for a 20kg ready mixed tub
if you mean the inside of a fire box as in a wood burning stove you need to use fire cement you can get the from victas aswell
i always find www.google.com a great help with problems ;D
Been asked to do exactly the same and after much searching around, I've been told S&C is the only way forward - It needs to be temp resistant to up to 500 degrees apparently ??
