mtec 200 problems
Lenno
second job with machine and had a night mare the machine keeps turning off when trying to spray
you have to keep pressing the green but on machine on when it does spray its realy wet and running down the wall
Best to call Andy on 07966394864 and he can help.
Are you setting the water properly and getting a consistent mix through the pressure plate before attaching the mortar hose
Reasons for the machine switching off:
- Water Issue or Air Issue
Cause of the material running down the wall:
- Incorrect water setting to speed ratio.
As mentioned before, it is best to call Andy directly for help
