Monocouche and K-Rend
I know in theory how to do these renders but how hard is it? I can flat render sand and cement to a decent finish and have done large dashing jobs to a good standard. Does it help if you can s&c render?
biggest thing to look out for is if you lay it on in two passes or coats that you don't break through to the first coat when scratching or your buggered. also joint marks can give dodgy texture lines if you overlap between lifts after a skin has formed
