minimum plaster thickness question
jez974
Hi,
I am plastering a small internal brick wall area and need some advice on what method to use.
I want to keep the thickness of the plaster and board to an absolute minimum so I can use the wall space for storage and have enough depth to fit in a bookcase.
Please can you advise what method I should use to finish the brick wall and minimise the final depth. the aqll is structural sound and has good insulation so its just about achieving a visually flat, smooth finish.
thank you
John
Try one coat plaster. You would get away with 10/12 mm depth. I take it there is no damp issues or condensation.
Thanks, there are no damp issues etc. So could I avoid using plasterboard at all and plaster direct onto the brick 10-12mm thick?
Use bonding coat pva first then lay it on like skim nice and tight rule it if you know how then skim if you know how
