Complete
Anyone tried one? I’ve got a rake of boarding with that habito board and it’s a bitch to cut
The yanks use them all the time. so I’d say they would be decent, cause they know the shitt when it comes to drywallAnyone tried one? I’ve got a rake of boarding with that habito board and it’s a bitch to cut
Are there no issues with gyproc dust jamming a jigsaw though?Makita say is best for cutting straight lines, so it's a fancy jig saw. If you are cutting to put up and don't have any depth problems then standard ceramic jig saw blades and a jig saw should be fine and cost a lot less. I use them to cut cement boards, lot less dust than a disc cutter and seem to last ok.
Love the BG promo for these boards - full depth blade cut-out for a box, then miraculously there is a large undamaged wood batten behind to fix to.
No.Are there no issues with gyproc dust jamming a jigsaw though?
Doesn't seem to be, even my cheap Wickes one has a pipe from motor that blows dust away from the blade. Hate the vacumm hose though, gets in the way, usually chuck it, I'm a bad boy but do wear a maskAre there no issues with gyproc dust jamming a jigsaw though?
Yea this stuff is a bitch to cut. Score an snap is more like score score score and break. I had a dewalt jig clog up an break within a day.Doesn't seem to be, even my cheap Wickes one has a pipe from motor that blows dust away from the blade. Hate the vacumm hose though, gets in the way, usually chuck it, I'm a bad boy but do wear a mask
I'm cutting cement board so a wood blade ain't gonna last, if this board is reinforced I suspect it will need a ceramic jigsaw blade. Even with the Makita fancy one blades will need replacing.
What would you recommend for tough boards mate? I’ve got 15mm fire board and acoustic on the same job tooGot the Hilti one and never use it.
Fireline and Soundbloc cut just fine using nothing more than a knife.What would you recommend for tough boards mate? I’ve got 15mm fire board and acoustic on the same job too
Even 15mm?Fireline and Soundbloc cut just fine using nothing more than a knife.
What blades you using?Fireline and Soundbloc cut just fine using nothing more than a knife.
Prob your limp wrists more than the bladeWhat blades you using?
Just because I think they are all shite at the moment mate.
Think the dewalt drywall cutter was similarThought they used a zip cutter which has rotary blade
The cut out tool is fine. To me, the cut isn’t as neat as a padsaw. Could always use a multitool too.What would you recommend for tough boards mate? I’ve got 15mm fire board and acoustic on the same job too
Yes mate.Even 15mm?
I honestly don't know, just bought a big box of them from my local tool shop. They were a more expensive one. They have a gold coloured cutting edge. Good quality.What blades you using?
I noticed the Hilti lads are crying out for them to bring out a multi tool.
Wish they would. I have a corded Fein but would prefer a Hilti cordlessonly be £600!
Reckon that’s what I will get. Quality tools. First one I had lasted 9 yrsCordless Fein here.
Really like it. Use it so much more than my old corded.
