microgobetis
Rigsby
TPF Special Forces
I have a job to quote for using Parex mono. There is a front and back 25m2 each and it is 2 parts old common brick 1 part new block.
He is wanting it cheap as poss as most builders would so I proposed micro on the brick and block with an expansion bead on the joint where the block built extension joins the existing brick house. This will create equal suction and save applying a pre-rend. Spray mono at 15mm with mesh embedded.
My question is how much micro will I need for appox 32m2 of brick and 18m2 of block?
I take it 1 bag of monorex per m2?
I have used Parex on micro before and seem to remember 30m2 a tub so yes 2 tubs by the sound of it. I also got 1.1m2 a bag on old brick but the wall was flat. So 55 bags for 50m2? Should be safe at that I hope.
He is buying so he can reclaim the vat but wants an all in price minus what his purchases are.
Very rarely work for builders but know this guy. Let him buy the materials and reduce the risks.
