micro gob is an SBR based primer, evens out the suction on tricky backgrounds, not a solution for painted surfaces (there is nothing that can gaurantee render over a painted surface) as warrior says the job will only be as good as and depend on how good the paint is and how well the paint is stuck to the wall, even render made for painted surfaces such as parinter is never 0 and they still advise to remove paint even with that product. I recon it would be better going onto micro gob with its grit than the shiny paint tho all the same but still risky
we use micro gob alot, our next job is painted but we are removing all the paint first with the powerprep then micro gobbing it
sucki sucki :RpS_drool:
