Marmorino classic blockwork with choco milk lucidato
Marmorino classic blockwork with choco milk lucidatoMarmorino classic blockwork with choco milk lucidatoMarmorino classic blockwork with choco milk lucidatoMarmorino classic blockwork with choco milk lucidatoMarmorino classic blockwork with choco milk lucidato
Some bigger pics for the lads :RpS_thumbup:
Them un's are better LSP.............what do you use to cut the grout joints with??
Thanks pal, i use a low tac car stencil tape. Apply the first coat of material your using then when thats set create the grout lines or pattern ect. Apply 2nd coat of gear straight over the tape and pull the tape off the next day when the plaster has set. The 1st pic above is ready to take the 2nd coat with the orange tape stuck on.
They'll be even bigger if you join photobucket not sure if anyone's mentioned it before Mr Stroker :RpS_biggrin:
:RpS_thumbup:
Photobucket, what's that?? They put cameras in phones nowadays - but buckets? Technology today is marvellous isn't it :RpS_thumbup:
apparently theres a photo finish too. Not sure how the camera survives in a bag of multi but there ya go!!!!!
Yes photo finish is quite good, no need for pva & only onecoat required, mind you it has to be used in dark rooms, maybe so nobody can see how rough it is :RpS_unsure:
