Mapewall gpr
duke163
Meshed and scratched a coat over shocking brickwork last week gonna top it tomorrow and not sure what to expect timing wise , anyone got any experience? Cheers
It says you can build it up to 40mm dubbing out. It's my mates house and the bricks were falling apart when he was hacking off the old render so it needed a coat just to hold it together . I'm hoping it's going to rub up quicker than a little panel on concrete block I one coated by hand Tuesday on another job .
I'd put some aceelerator in it if I were you.
We put a top coat on some plinths at about 8mm and it took hours to go off enough to float.
Good kit and can go on thicker just mesh the first pass if it's that much thicker than normal.
We should have it sprayed by 9 but some of it will be up to 20mm thick . Only been using the machine a month and not used accelerator yet , how do you gauge it with the butt refilling itself mate ?
Put 5 litres in and let it run three quarters down
I'm putting 7.5 in today spraying sas prorend float coat at 12mm with mesh
I'll be getting my lights out ready!!
Yes it's ideal
Some will say it fucks the machine up mind
Let us know how you get on with the gear[emoji106]
I needed the lights as well . Some of it was thicker than I thought and we didn't get it on too quick either but gear was good . Cheers
SAS float takes an age to go off, as does the top coat.
I think it's a bit like parmurex as in its like there mono without the colour
I did 50m2 yesterday 2 passes with mesh and was finished by 4
Wickes hurry up helped me along mind!!
I put some top coat on the other day on prep, all on by 10 ish, it was ready to cut back.....2ish the next day.
That's the float they do the prep is more like an adhesive.
