S Scotty5 New Member Apr 15, 2025 #1 Hi, looking to turn bull nose corners into right angles. My thinking is to use bonding to build the angle out and let it pull in before applying a corner bead. Would this work? If not, any experienced got an idea? Thanks in advance
paulf Well-Known Member Apr 15, 2025 #3 Scotty5 said: Hi, looking to turn bull nose corners into right angles. My thinking is to use bonding to build the angle out and let it pull in before applying a corner bead. Would this work? If not, any experienced got an idea? Thanks in advance Click to expand... Get your straight edge out square it up with bonding.
Spitandpolish Well-Known Member Apr 15, 2025 #4 paulf said: Get your straight edge out square it up with bonding. Click to expand... You wouldn't have a clue with regards to that sort of thing would you ,,,, just making it up as you go along...with a wish and a prayer as standard !
paulf Well-Known Member Apr 15, 2025 #5 Spitandpolish said: You wouldn't have a clue with regards to that sort of thing would you ,,,, just making it up as you go along...with a wish and a prayer as standard ! Click to expand...
Spitandpolish Well-Known Member Apr 15, 2025 #6 paulf said: View attachment 81738 Click to expand... Your G** twin looks like a right prick mate !
paulf Well-Known Member Apr 15, 2025 #7 Spitandpolish said: Your G** twin looks like a right prick mate ! Click to expand... Yes
ChrispyUK Well-Known Member Apr 15, 2025 #8 Spitandpolish said: You wouldn't have a clue with regards to that sort of thing would you ,,,, just making it up as you go along...with a wish and a prayer as standard ! Click to expand... You back on the Robinsons high juice mate?
