M300 maximum height ?
mark ross
Whats the highest any ones pumped with the 300.
We have got to go vertical 18 metres, with another 15 metres horizontal, and 6 from the pump to the scaffold.( pumping Weber LAC)
Hi Nick,
Thanks for the feedback.
I'm guessing your using the Mtec Star for your base coats .
What was your hose configuration. ie 35mm @ 26m and 15m @ 25mm ?
We were using the 11l/m R&S (blue) using 13.5m 35mm and the rest 25mm hoses.
We did find it easier forking the machine on to scaffold to access all areas, as the scaffold was of dogbone spec so no cross bracing to restrict movement.
65m is the most I have ever pumped on a block of apartments in Sheffield we needed a cheery picker to carry the pipes up to the top and burnt out a twister every day running at 40 bar . And we had a G5
