look
nickelarse
i thought about that the other day actually. just thought the starwheel wouldnt pick it up. i can imagine that slide running out pretty quick tho
PFTwales
depends on the pump ur using. a d6-3 will wanna pump 20 lts. a d4-3 will do 12lts. insise is only 10mm ish so a d4-3 is ok. a mixer like that holds 150 ltrs.
Rigsby
TPF Special Forces
I usually on put on 10mm like Granicem (11mm) or ocr 9-12mm on rend-aid. The 4-3 is ideal as a 6-3 is too fast.
