Who is advising you.I'm skimming the whole house, all lath and plaster and am being advised that there is no need to use lime putty on external walls as the cavity behind the lath deals with moisture. Is this correct? Can I use gypsum?
If it’s solid then skim it, what’s the worst that can happen??I'm skimming the whole house, all lath and plaster and am being advised that there is no need to use lime putty on external walls as the cavity behind the lath deals with moisture. Is this correct? Can I use gypsum?
u obviously haven't got a fkin clue palYup, skimming the lot
That's why I'm asking for advice from experts like youu obviously haven't got a fkin clue pal
It’s in the diy section not the oap grumpy section!u obviously haven't got a fkin clue pal
It’s in the diy section not the oap grumpy section!![]()
