T
Tam Ross 1888
Guest
Guys what’s the best way to tackle an 80m2 ceiling on my own.I won’t be able to coat and second coat the same day due to its size and height.Im concerned about sectioning it because I can’t do it on one day.
Joint it with a piece of scrim . Peel it off on last trowel them do another gauge. If it scars slightly easy fill itGuys what’s the best way to tackle an 80m2 ceiling on my own.I won’t be able to coat and second coat the same day due to its size and height.Im concerned about sectioning it because I can’t do it on one day.
4 cans of red bull shorts and t-shirt lab passing hawksGuys what’s the best way to tackle an 80m2 ceiling on my own.I won’t be able to coat and second coat the same day due to its size and height.Im concerned about sectioning it because I can’t do it on one day.
Thanks mate was a little concerned about the blending to be honest.Ceilings about 20ft high so no one will notice.lol.I would do half with first and second coat but do not cover first coat entirely.
Next day start from other end (fresh and when you get to previous work blend it in.
My blending in is second to none, skimming is s**t though.Thanks mate was a little concerned about the blending to be honest.Ceilings about 20ft high so no one will notice.lol.
No getting the scrim thing mateJoint it with a piece of scrim . Peel it off on last trowel them do another gauge. If it scars slightly easy fill it
Not got anyone else.Ffs get another lad on it with you
Put scrim where you want to skim to. Pull it off at end . It will leave you a nice little edge to skim in to. Worse case you got a line to tickle with paper.No getting the scrim thing mate
Thanks mate good tip.Never had to do that before as I have always managed to two coat a ceiling on one day.Put scrim where you want to skim to. Pull it off at end . It will leave you a nice little edge to skim in to. Worse case you got a line to tickle with paper.
40 meters one day, completely finished. Pull the tape and you've got a fairly nice line to work up to the next day. I usually wet the hard edge quite a lot, rather than weak pva mix, just skim the rest of the ceiling and clean any over spill on the joint.Guys what’s the best way to tackle an 80m2 ceiling on my own.I won’t be able to coat and second coat the same day due to its size and height.Im concerned about sectioning it because I can’t do it on one day.
agree, could probably roller it on.20 ft up , one coat will be good enough
You’d be able to spray it with s**t after 4 cans of thinking juice.4 cans of red bull shorts and t-shirt lab passing hawks
Use the scrim as a nice straight line to work to . Saves using g a straight edge or toe of yer trowelNo getting the scrim thing mate
A was actually thinking that.20 ft up , one coat will be good enough
To cut it off .Use the scrim as a nice straight line to work to . Saves using g a straight edge or toe of yer trowel
Bullshit! You would be hanging out of your arse on a 10m2 lid.I would do half with first and second coat but do not cover first coat entirely.
Where you based? Maybe a one or two lads off here could help you for a day on it for the right moneyA was actually thinking that.
i would use you as me splash brush you cockneed tosserBullshit! You would be hanging out of your arse on a 10m2 lid.
So you can write/speak plain English you bloody fraud.Put scrim where you want to skim to. Pull it off at end . It will leave you a nice little edge to skim in to. Worse case you got a line to tickle with paper.
You’d have to pull it out of your arse first after I’ve rammed it up there for you.i would use you as me splash brush you cockneed tosser
Firm but fair.You’d have to pull it out of your arse first after I’ve rammed it up there for you.
You've tasted the bukkake of failure.I've tasted the future, hot pork crunch scratchings cooked in microwave.
Thistle scrimtape ?Use the scrim as a nice straight line to work to . Saves using g a straight edge or toe of yer trowel
smart c**tA was actually thinking that.
