krend repair
might be best redoing it altogether its only 6m whats the best procedure for going over the top of it hp12 or something like that size of beads 15mm again cheers
If it's flat no bumps but just the finish is not great. You can prime with the TC primer in the colour you want then TC over the top which means no hacking off no re beading cos it's just 1.5 mm over the top. Yes comes in the tubs I just add a little splash of water and a quick spin.
what about the square repair first should that be done with krend again or just some OCR or something first
A bit late for this post, but for anyone still looking...….my experience is that getting a colour match is near impossible, that said, the texture match is relatively easy. I use neat SBR on the patch and especially the edges and rub back very gently. If you are looking for an invisible repair, get ready to shell out on K Rend Colour Enhance paint. I understand that Weather Shield works well although I have never used it myself and could not comment on colour matching. I am always open to further advice, every day is a school day!
