krend hp 14 onto timber frame render board
253D577E-ACB9-457A-86F5-9E1EE8F217E5.png Here is a BBA certificate that states you can use Hp12 and TC15 over a CP board but it does not specify which CP board .
If you look in their literature there is a lot of info that will assist you when you are specifying jobs .HP14 can also be used .
View attachment 19774 Here is a BBA certificate that states you can use Hp12 and TC15 over a CP board but it does not specify which CP board .
Ok thanks for your help mate.
The reason I asked is that I've a 30m2 shed to do and I have bags left over from a job and I was gona use them. And he wants to paint it on completion
I find the hp14 rubs up lovley just like s&c
It’s a good starting point , Cembrit Knauf & Euroform are popular and are always updating materials.
Remember these are for Render only ,if you are fixing insulation a different type of carrier board should be used but the company’s named can provide details .
