It’s the new lightweight scratch render used it a couple of times .
Can be used on Insulation and masonry with mesh applied between 2 / 9mm coats .
Scratched back to 15mm beads
Laid it on in the afternoon and scratch it of in the morning.
Also can be dashed
Hand applied or spray
It’s a brave choice putting it straight over the eps but I suppose that’s what it’s made to do
I personally wouldn’t use it
I’ve used parex ehi over Maite and it’s decent
I’d go for a thin coat system anyday due to the weight
