kauf skim plaster
Knauf ,in my opinion is best plaster on the market, just coat beads , doorframes etc in front of yourself, and do a rolling set. It covers 15m2 per bag so three sets a day , moneys in. That's 6 bags a day 90m2 ,dead easy
Yes I like knauf - nice and creamy but very very hard to source from as multi are everywhere plus merchants offer competitive prices for multi
If someone decides they like knaufs skim then it makes sense to buy a pallet as long as you have room to store it. Then it doesn't matter who you order from as probably next day delivery.
Knauf is great to use, I used it for five years when I was doing site work, as has been mentioned before , fill all your beads , tapes out , then basically use it the same as pink. You can get away with one thick coat but I still prefer to lay it in . Knauf goes much further per bag to and is lighter to use
Hi Hick
Do a search on the forum for MP Finish... there have been a lot of posts recently, also some videos posted....
There are a lot of guys on here using it a lot as well.... @theclemo, for one, seems to only use it....
Good Luck mate
I've been using some kauf finish plaster lately. I've been finding it a bit arkward to use any tips?
The best tip I can give u mate is mix it ticker then multi. It should just about pour out of the bucket. And as said coat beads and joints first.
When u get in to mpfinish mate u won't go back to multi.:RpS_thumbsup:
Cheers lads thanks for the tips. I've got ten bags to get through, I'll be an expert with it by then,
I did notice that it takes a bit longer to go off than multi.
Don't use much water when troweling it. And if u have a refina s*p*r*lex u don't need any water to finish it. After u give it 2 trowels put the next hit on then u can fall back and give the first hit a polish. When using it mate u don't have to get back on it as early as multi.
ps. If u don't have a s*p*r*lex @Marshy is a rep for Refina he will help u out.
No no no! I'm not a rep for Refina or anybody else?? Mind you if they want to offer me a job I'm all ears?? :RpS_wink:
Hi Hick
Good Luck mate
If only i knew a local rep who could get me a couple of bags to have a play with Rich or even to invite me to a local knauf demonstration..........................:rolleyes) @Runswithscissors
