Hiya
We sprayed 45m2 this aftetnoon with our strata pump for the first time which went pretty well considering it's the first attempt! The pump worked brilliantly which was a relief after the bad experiences Iv heard about on here.
Only problem was we were spraying k1 silicone onto hpx but it just wouldn't pick up at all I tried ruling it when it first went on but it was too wet. Then tried a bit later and then it started slumping and a few bits fell out and the basecoat was saturated on the surface. We had to brush it off and put it back in. Got it sorted in the end with a bit of perseverance and swearing but is there something I'm missing here? Or do we need to leave the hpx longer? Went on it 24 hours later and it was rock solid. Or do we just need to spray the k1 a bit stiffer?
