K rend gp mortar
User___removed
i have a few jobs next week using this.
I will use it as a 2 coat material so after any info!!
Does the 2nd coat pull in when sprayed?
I will be using the Regina power sponge also.
Has anyone used one with 2 coat work?
Cheers
Hi bobby
I sprayed this back in May,sprayed nice through my ritmo we done it in two coats first pass scratched and left for a few days then sprinkled over with a big of water then topped.
Went over it with a power sponge after about 3-4 hours and it was nice then just finished it with a quick sponge over by hand,just need to get the timing right before you hit it with the power sponge.
Still had a couple of cracks the next day but only small ones that could be patched in before we tyroleaned it so didn't matter to much.
It's nice gear not much difference from OCR to be far.
I also used it on a job in Chippenham about six weeks ago on some garden walls and it was a bit chilly and there wasn't much sun on the walls and that did take longer to go off so get it on early if the temps are down and it's in the shade,oath wise take some lights
