K rend Base Coat
jlaspire
Hi All, Just after a bit of help if you can.
Can I use K rend base coat as first and second coat and then just paint it?
I've used it before years ago but was 1st coat with mesh, second coated and then finished with Silicone coloured finish.
Any help would be appreciated! Thanks in advance!
Jon
S a plastering
Jon
if your going to do that why not just use Weber OCR or did you want to get it on thin
jlaspire
Just looking for the easiest option with something I can just paint to match the colour of the existing house as it's an extension I need to render. I've used the k rend base coat before which seemed easy to get a good finish. Not sure on how to finish Weber ocr.
jlaspire
Hi madmonk. Had a look into Weber Orc last night and looks straight forward. Will see if the local Huws gray stocks it today. Looks good to work with. Can I do it in two coats up to the 16mm before it sets? Going onto new ultralight blocks. Thanks for your help!
S a plastering
did this yesterday with little job
