Very similar to the marshal town flexi thing and the nela flexi thing, softer than the Refina ones. . Sexy timesOx ulteaflex any good
c**tUlteaflex .....genius .
U put on and lay in with this trowelAmazing trowel Andy just always use the heel with it or it will cut through each spread looks a c**t
Might be worth permashaping it with a vice or hammer gently if your careless c**t
No ffs you butterbrainU put on and lay in with this trowel
Who does?U put on and lay in with this trowel
Nick it orredyrr f**k**g s**tJust bought two new carbon steel trowels with wooden handles, one Marshalltown and the other is one @Vincey told us about a curry one from America seems a nice piece of steel good weight and balance possibly steel a bit thicker than Marshalltown, got a 14 inch hawk too nice, bit heavier than Marshalltown but thicker and more substantial so I am a happy bunny and @Vincey thanks for the heads up about Bon tools
In the f**k**g wheel basterd binWhy don't you just use it Andyg then report back and tell use how you got on and what you think .
You need carbon steel Andy non of this expensive s**t where you need a van for all the different trowels some of these buggers useNick it orredyrr f**k**g s**t
STFU you old c**tYou need carbon steel Andy non of this expensive s**t where you need a van for all the different trowels some of these buggers use
@beaderWho does?
how old is old ?What the f**k does that mean you even older and dead c**t
Incorrect . I lay on with a carbon MT only trowel up with an OX Ultraflex.
Correct.....Weird
How does everyone do them little faces ? I’m a technical retardCorrect.....![]()
Not what you said a few months ago... I can’t be arsed to find it, thought it was odd then though!Incorrect . I lay on with a carbon MT only trowel up with an OX Ultraflex.
DO you rub your carbons with a bit of bread and butter?Incorrect . I lay on with a carbon MT only trowel up with an OX Ultraflex.
No i am afraid you are getting me mixed up with someone else .Not what you said a few months ago... I can’t be arsed to find it, thought it was odd then though!
No carbs for me thanks but butter is goood.DO you rub your carbons with a bit of bread and butter?
Yes m8 as good as any trowel what wrong whith a worn in Marshalltown trowel does the job as good OK might be easier on the joint at the end of the day it all money making the old plastrers only had one trowel and some of them were s**t odds at skiming a trowel not going to work miracles as a i say you got it or you haven't like the rocket ronnieOx ulteaflex any good
GET f**k*d there only one rocket, RonnieYes m8 as good as any trowel what wrong whith a worn in Marshalltown trowel does the job as good OK might be easier on the joint at the end of the day it all money making the old plastrers only had one trowel and some of them were s**t odds at skiming a trowel not going to work miracles as a i say you got it or you haven't like the rocket ronnie
No just not got my facts right probably, remember you like using it.No i am afraid you are getting me mixed up with someone else .![]()
Yes the chimpGET f**k*d there only one rocket, Ronnie
He on Monday which and learn boyYes the chimp
I do but only for troweling up.No just not got my facts right probably, remember you like using it.![]()
