Internal insulation for bedrooms with Solid Brick Walls
markhood1982
Hi All
Am after some much needed advice, am looking to insulated some internal walls for a couple of bedrooms using Kingspan or Celotex Insulation Plasterboard with a VPC ~ 62.5mm+ on the outer wall side. See picture attached of Bedroom 1. If I use the boards for one wall which will join onto a solid internal brick wall how can I reduce the risk of thermal bridging and cold spots - at the moment it has mold in the corner.
I was thinking about using foil tape on the internal sold brick wall or tape the foil tape around the insulation plasterboard edges to help form a thermal barrier then install the insulation board.
Many thanks
Mark
  • Internal insulation for bedrooms with Solid Brick Walls
