I know some systems have a foam available for fixing the insulation boards but has anyone ever used Pink grip dry fix adhesive to fix their boards. The spec sheet says they can be used to fix insulation to masonary and if they can fix a plaster board to a brick or block wall they will defo fix eps to masonry.
The adhesive is only really a base cushion to sit your eps straight and relys on the big fixings to secure them.
The dry fix adhesive cost about 5 quid a can and will do about 15 mts of plasterboard so i estimate it will do about 10 mts of EPS which is about .50p a mt
