Hello
just after some advice on best course of action on insulating a single brick garage wall, guy has said he only wants the best materials to be used, cheers for help
you could fix metal furrings with dab at 600mm centres and then screw insulated boards to them-level of insulation depends on how much of the room he,s prepared to lose
Same as but use 50mm or 75mm insulation as you dont see 60mm timber about, so you would need to pack all the batterns out 10mm to allow for the insulation.
push the insulation to the wall and batten over the top at 400mm centres using 120mm screws sandwiching the celotex between the battens and the wall. then board and skim.
still say id use gypliner and screw insulated boards to it, that way you create a cavity and level everything up and wiring and services etc are a doddle.
