insitu elliptcal arch
sygooner
Hi all.
I've got to run a staff bead on an elliptical arch in situ . If it was a semi circle i'd use a gigstick and cross brace but being elliptical can't help thinking it would be easier run on a rib rather than spinning from 3 points.
Gigstick or rib
Thoughts anyone
Stevieo
Royal Spin Doctor
Hi all.
I've got to run a staff bead on an elliptical arch in situ . If it was a semi circle i'd use a gigstick and cross brace but being elliptical can't help thinking it would be easier run on a rib rather than spinning from 3 points. Thoughts anyone
You need a bit of calculus.
Best ask Isaac Newton or get a spirograph
The Hobo
Hi all.
Gigstick or rib
Thoughts anyone
peg mould maybe
sygooner
peg mould that would sit on a rib or hung from a template only problem with a template is i've got to float the walls first with coarse stuff and its gonna be soft to run on
The Hobo
you cant rush this kind of work/but your heading along the right road in what you say
