Some customers just get told "no" John.Think I posted this before. When customers insist you skim stupid placesView attachment 62536
They would now as I wouldn't fitSome customers just get told "no" John.
My head wouldn't fit in there!Think I posted this before. When customers insist you skim stupid placesView attachment 62536
Your head definitely wouldn't fit wee manAnd it’s a No from me.
All bout that extra yardNo. I wouldn’t be stupid enough to do it in the first place.
I hope it was worth it. Did he shine a torch in there?All bout that extra yard
No but they sanded walls before painting.I hope it was worth it. Did he shine a torch in there?
Perfect walls are flat and matt and don't need sanding mate. But we all know that's not always possible to achieve.Crazy thing.
A good decorator will give perfect walls a quick rub with a sanding pole
Perfect walls are hazel laths covered in a mix of straw, twigs, horse sh1t and mud in between oak beams. Anything else is just a passing fad and unnecessary hassle IMHO.Perfect walls are flat and matt and don't need sanding mate. But we all know that's not always possible to achieve.
Did they put horse poo in it?Perfect walls are hazel laths covered in a mix of straw, twigs, horse sh1t and mud in between oak beams. Anything else is just a passing fad and unnecessary hassle IMHO.
Apparently not anymore it’s all about the shine, they want to see your face in it lolPerfect walls are flat and matt and don't need sanding mate. But we all know that's not always possible to achieve.
Yes, IIRC something to do with it starting out as acidic and then turning neutral over time helps it set stronger/harder than just mud. Cow sh1te apparently goes the other way from neutral to acidic over time which is why it's not so good.Did they put horse poo in it?
Flipping flip flops your a font of knowledgeYes, IIRC something to do with it starting out as acidic and then turning neutral over time helps it set stronger/harder than just mud. Cow sh1te apparently goes the other way from neutral to acidic over time which is why it's not so good.
A top decorator will run a sanding pole over fresh plaster . Not many will I only seen it a few times . I actually thought is it so paint sticks betterPerfect walls are flat and matt and don't need sanding mate. But we all know that's not always possible to achieve.
I’ve seen a decorator kicked of a job for sanding fresh plaster. My job!!A top decorator will run a sanding pole over fresh plaster . Not many will I only seen it a few times . I actually thought is it so paint sticks better
It was easi fill he was sandingI’ve seen a decorator kicked of a job for sanding fresh plaster. My job!!
It is so that the paint adheres properly, but that's why plaster is supposed to be finished matt, not shiny.A top decorator will run a sanding pole over fresh plaster . Not many will I only seen it a few times . I actually thought is it so paint sticks better
Aye but it’s not insurmountable! There is paint for new plaster these daysIt is so that the paint adheres properly, but that's why plaster is supposed to be finished matt, not shiny.
But even then the plaster is supposed to be matt.Aye but it’s not insurmountable! There is paint for new plaster these days
But that’s a whole different sausageEven a car sprayer who is aiming for a show-standard ultra-gloss finish will key the primer layer prior to spraying on the top coat.
I know a couple top brush hands, and they lightly pole sand between coats. Plus know a paint sprayer who sands before spray after spray then second spray rubs again then finish/final coat with roller and it’s feels the b*ll***s sooooo smoothIt may be different, but the point is that if a wall is over-polished by a spread, then I personally have no objection, in principle, to a decorator giving it a rub-over with some P220 before painting it.
I suspect most of us have seen emulsion flaking off modern plaster in one house refurb or another, in circumstances where either the plaster was a bit over-polished and not keyed to compensate, or where it wasn't mist-coated properly.
Keying a surface before painting is legitimate for cars and it can be legitimate for decorating a plastered wall - whether a spread gets their nose out of joint about it is irrelevant. Would you take any notice of a builder who insisted his walls should have no further prep by a spread before they were plastered?
You’re a f**k**g brush hand.I know a couple top brush hands, and they lightly pole sand between coats. Plus know a paint sprayer who sands before spray after spray then second spray rubs again then finish/final coat with roller and it’s feels the b*ll***s sooooo smooth
