How much is too much?
ScottHastie1
How much freeflow in a batch?
5.1 in belle mixer and adding 15l of water
Says on the tub 1:30 with water so thats 500ml freefow? seems a lot
Also anyone ever mixed freeflow with sbr?
I've found 125ml was fine
Enough to plasticise anx make a nice mix anyway.
If you primarily need it more waterproof that'd be a different mix design.
Good to see you back on Rigsby , hope your well bud (y)
Hey Rigsby,
I've been reading your old threads relating to SBR. How did you get on searching for the idea sbr mix?
2.5-3l for polymer modification? I tried it out only with 2l tho was fine in the scratch. great adhesion but nightmare to float. I assume thats why they let it go off and use the scratcher to get the finish.
