How can I avoid the join when spraying parex textured finish?
Bsr
I can't seem to spray a textured/tyrolean finish with parex without getting a big join line along the scaffold. I know if you spray over sections after it gets a skin on then its a different shade straight away. I'm guessing by the time I do the elevation and drop down the skin has already formed so when spraying the next elevation I get a dirty mark along the scaffold. Any tips???
at a guess with out being flippant, id say set your scaffold up better. parex is a slow setter anyhow, so you've got more chance than most. this time of year you should have a good 10 minutes to drop down a lift, if that isn't enough time get another body on the job to take over below.
Think it may be a combination of as u say the scaff too close and the 2 main times its happened it was both a freaky red hot day. I'm thinking if that hot again to do smaller bands to beat the join??
