PhilPlaster
When you say how many hits you do regardless of how many bags for now, do you lads include closing in as the same hit or not?
Bruce Willis said:Thats what I thought. So one wall complete or what ever you can get on eg ceiling, 2 walls finished is one hit?
Im askin if you class one hit from start to finish or first and second coat of same areas as two hits. Its sorted now mate, Im onto the next questionsteve cov said:Bruce Willis said:Thats what I thought. So one wall complete or what ever you can get on eg ceiling, 2 walls finished is one hit?
your confusing me again
ziggy2 said:I use it out the bucket with a coal shovel, I used to use a spot religously but when my mate left I just ended up using the bucket, takes less carrieing, cleaning and setting up, never looked back to be fair, horses for courses!![]()
Hello bruce ive tried many ways of mixing plaster whether it be undercoat plasters or onecoat or board or multi- finish many plasterers work from the bucket as do many from the spot as for setting times well we all know if its in the bucket or on a spot board once mixed it has to be applied as quickly as possible i honestly think theres no difference at all in the setting time.I do think tempretures play a big part in the setting times like colder months the curing lasts longer than in the warmer months out of curiosity i might mix up some plaster and see which sets the quickest on the spot board or in the bucket in theory it should set quicker on the spot because more of the plaster is exposed to the air but me physics are a bit rusty at the moment i do have a plasterers bath for undercoat plasters selco sell good ones made from polyprop cheers jimfish.Bruce Willis said:All that bending! Doesnt air get in those gorilla tubs making the gear go off quicker? In fact when I ve worked out of a bucket I think its always gone off quicker.
