Go and serve your time.Hi everybody, i am after scudding two walls one 42ft by 6ft high and the garage is 18ft by 9ft high, i need to try and put on a scratch coat, how many 25kg bags of cement and 25kg bags of sand do I need for the scratch coat only
Weber ocrHi everybody, i am after scudding two walls one 42ft by 6ft high and the garage is 18ft by 9ft high, i need to try and put on a scratch coat, how many 25kg bags of cement and 25kg bags of sand do I need for the scratch coat only
Use an online calculator for the garage area. Buy a few more bags than it says just in case.Hi everybody, i am after scudding two walls one 42ft by 6ft high and the garage is 18ft by 9ft high, i need to try and put on a scratch coat, how many 25kg bags of cement and 25kg bags of sand do I need for the scratch coat only
Not going to go well for you I suspect.Hi everybody, i am after scudding two walls one 42ft by 6ft high and the garage is 18ft by 9ft high, i need to try and put on a scratch coat, how many 25kg bags of cement and 25kg bags of sand do I need for the scratch coat only
