Might as well leave it till end of year nowJust started to do a 12’x11’ bedroom old plaster removed back to blocks as in bad state not worth patching. Should I clean mixing bucket after each mix or just at end of day,thanks guys.
Do as @John j does and leave it till the end of the week mate.Just started to do a 12’x11’ bedroom old plaster removed back to blocks as in bad state not worth patching. Should I clean mixing bucket after each mix or just at end of day,thanks guys.
That's the least of your worries mateyJust started to do a 12’x11’ bedroom old plaster removed back to blocks as in bad state not worth patching. Should I clean mixing bucket after each mix or just at end of day,thanks guys.
Pmsl.
Looks like Aglee ?
Lump hammer or rubber mallet?Do as @John j does and leave it till the end of the week mate.
A hammer brings it up the business.
Feck thought it was 1.5 metres nowYes clean them after every set, singing happy birthday and keep them 2 meters apart COVID will get in the mix?
You work for DB products, don’t you,can get the cheaper at b and mI tend to buy 30L plastering buckets in bulk from Direct Building Products, usually order about 500-600 at a time which will last me a couple of months. and keep 10-15 in the van at a time, after every set I’ll just get rid of it or use it as a washing up/rubbish/piss and s**t bucket.
Hope this helps
Jack hammer.Lump hammer or rubber mallet?
