Help with getting a straight line on vaulted ceiling line.
Theartfulbodger
If you have plaster board at an angle joining at let's say 1120 degrees and you want to get a sharp edge what is the best bead to use, I found a plastic ' multi purpose one " online, do screw fix sell this. The reason I ask is I've had a plasters do some work and the joint line is shocking wobbly and bumpy. I have plastered walls ( most if the house) in
the past so I'm going to fix this bit just need a little advice to get it bang on..Thanks in advance.
Can you post a picture please? Always easier to advise with a photo.
Have you asked the guys that did it if they can straighten it up?
Chalk line.
I don’t know about that, but if I said I would make sandwiches I would, there must be a pressing reason for Andy not to
I don’t think he appreciated my attitude and suspected (rightly so) that I probably snapped my fingers at him. He also refuses to be a loyalist in my Court... I’m Queen you know :sisi:
I asked you to make my sandwiches.... as my royal sandwich maker.. I got some backchat but regardless ..... sandwiches
Oh I do vaguely remember you waffling on about something like that. I obviously chose to treat you with the same contempt as the other royals.
I use this
Bg changed the name of the tape now to something else but imo it’s the best for angles use tradeline ready mix to bed it in then skim it when dry
1 minute 28 seconds in on video
