aye marra, get back to the G** channel and knock ya sel ootcan i look back on the xxx channel now lol
sorry keith im here now lol 160 on the water 5 on the speed for me arti
When spraying Rendaid easy just to take a brush to it ,that gives the key
https://www.plasterersforum.com/thr...ockwork-on-new-build.49933/page-2#post-688727I never mesh in the rend aid ,asking for trouble , the mesh should be at least 6/8 mm from the face work
I put it in the base as if the substrate is going to move these sticky base that is well stuck to the substrate and fully reinforced with mesh will help hold the substrate together.
Plus of course stress patches in the render coat.
I have though on bad walls that are thick enough put mesh in the base then stress patches in the render and fully meshed again.
Did a thick Jub ocr recently on a South facing wall. Fully meshed base coat then mesh again at half thickness, including stess patches at 45 dehrees then mesh again 2 mm from the top. Notorious for shrinkage cracks over 10mm and facing south.
This wall though not the slightist craze anywhere. But triple meshed no wonder.
that is bang onI put the mesh in the base. Two reasons, 1- the thinking is that cracking will start from the structure through the base into the render so if the base is strengthened the top layer is protected by being on a reinforced background. No technical expertise to back this up just my experience and opinion. Reason 2 - on really bad substrates the thickness of the finished top coat will inevitably be thick in some parts and thin in others, putting the mesh in the base removes the risk of rubbing down to the mesh in thin areas.
Always done it this way and I have never had a complaint about render cracking or failing I obviously don't get back to every render I do but I'm sure I'd get a call if any cracked and I have been past a few a did years before and so far never had any issues.
it may be correct to scrim in the mono .
we put the mesh in the rend aid as you have more time at that stage then when you apply the mono. the last thing that you want is to scratch back the mono and touch the scrim.
I always do one thick coat as it's quicker by hand this way so to put mesh in the finish would be a ball ache.maybe this is what Malc means?I havnt used mono but u say about time ? Is that more just time to get it on the wall ? I dont have a machine but i could imagin a tight quick coat mesh then go on top?
