Ok sprayed fine with the jet yesterday, put a new r&s on today kicked it up to prime machine, the motor turned then stoped but the light stayed on and the water pump kept working and feeding water to the mixing zone. But no life from the motor
Inside yeah buddy. Normaly works when I reset. Or the big black switch inside in the middle. But nothing. I press the on button and the water pump fires up as if the motor is on
My plan tomorrow buddy was far to busy to get involved with IT today. So I got the whisk and decided hand applying was out the question. So I beaded up ha
