Help, Damp from next door
nala
I live in a semi detached Stone built house. I have damp in my dining room in just the one corner which is a joined to the party wall next doors ground is alot higher than ours, what would anybody advise the right way to sort this out. :RpS_crying:
Arti
check the easy stuff first like the pointing/something bridging the DPC from the outside or ,maybe a condensation problem.. get a trustworthy tradesman to come and have alook for you...............:RpS_thumbup:
Fatarm
Trainee mod
Is it in the corner adjacent to you neighbours ground is higher? As arti said the raised soil level could be bridging the dpc? Welcome by the way:RpS_thumbup:
martinemj
worse case
if next doors wall higher it is possible there is a damp issue...
either tanking or a membrane on the wall to stop damp....replaster
but agree with above...get someone who has good understanding of damp to take a look
hope that helps
keithuk
As Martin said ,if it is a high ground level .get the damp guys in ,what area are you in?, someone may be able to recommend a good company
Rhys
Not a water table issue is it, with all the bad weather recently?
might be no dpc if its stone built - sounds like tanking is the sensible option.
