Rip it down or overboard it once lathe and plaster ceilings start cracking or need repairing it’s losing its bond pointless repairing themJust looking into repairing an lathe and plaster ceiling. Basis simple question which BG technical can't answer. What happens when you put multi thistle bonding on lime lathe and plaster.
YesI’ve Never heard of multi thistle bonding is this a new thing?
Pictures or you’re lying!
Usually goes in your eyes wrong stuff m8 carefully cut a square section out to nearest joists board and skim failing that get a plastererJust looking into repairing an lathe and plaster ceiling. Basis simple question which BG technical can't answer. What happens when you put multi thistle bonding on lime lathe and plaster.
Laths will expand when wet, they then dry out and the plaster will move and crack With any movementJust looking into repairing a lathe and plaster ceiling. Basis simple question which BG technical can't answer. What happens when you put multi thistle bonding on lime lathe and plaster.
Chrispy, on a good day .
