Hello - I need advice regarding internal wall insulation
I live in a 1930s house near Croydon, the external walls are not insulated neither does it have any gaps between the bricks. I am planning to insulate the inside wall surrounding the window in the upstairs bedroom (size 13"x11").The walls are very crumbly and the plaster has come off in places. We decorated this room years ago in the early 1980s.
My plasterer suggested using a thicker insulated plasterboard round the wall and round the window slightly thinner insulated plasterboard to fit the width round the frame. I have read online that the internal walls can also be insulated using wooden strip batons and then insulated in between. I have fitted wardrobes on one side along the chimney breast. He would also have to insulate the external wall inside the fitted cupboard.
I am not sure what is the difference between the ready made insulated plasterboard or inserting insulation between the batons. My plasterer said that putting batons up will be more expensive alternative.
Also, are insulated plaster boards fireproof?
I also have very heavy curtains. Will it be easy to drill holes and would the plasterboard be able to support the weight of the heavy curtains?
There is a radiator under the window which would have to be moved slightly forward to accommodate the insulated wall. There are pipes in the corner which I don't believe are functional any more.
How much would it cost approx? I have asked the plasterer to plaster 3 walls, two internal walls and one external and the ceiling which has a crack going right across the room. We can't plaster the other fourth wall as it is surrounded by fitted wardrobe.
I would also like to get extra sockets put in the room. Can anyone recommend a qualified electrician and a plumber to take off the radiator and move it forward after the plasterboarding?
Thank you.
Empty water, remove radiator, remodel pipes for radiator. Pull wire for socket. Fix electical socket box (not necessary). Create metal or wood frame for platerboard. Fit mineral wool insulation boards - 8cm thick. Add vapor membrane and close with plasterboards, can use fireboard. You will need a new window board. Install radiator to new position. Complete electrrical socket. Go through jointing and plastering steps. Paint new wall.
Why do they need to be fire boards. Knock plaster of . Move rad pipes . Get first fix for new socket. . Dot qood thickness and good quality insulation boards on . Long screws for curtain pole or put a plinth up or get a blind lol
Insulated plaster 80mm for north facing wall, 50-60mm for east, west, south facing walls, may be a good solution as well, but it would contain some foam material, if you are allright with it.
Your level of insulation will be determined on how much room you can afford to lose on your walls.
a good system I found if space is an issue is:
Treated stud timber on walls fixed at 300mm intervals,25mm celotex/kingspan etc.. in between batons then 27 mm gyproc thermaline plus insulated plaster boards.
I would never dot & dab any type of plasterboard onto an external wall with no cavity.
Internal walls can be just dot & dabbed with standard plasterboard.
Your fixings for radiator/curtain poles etc....can be dealt with at baton fixing stage, just place extra timber on wall where they are going to hang.
Done all my upstairs no probs
Polyurethane foam adhasive can be used as alternative. Either way it would be advantageous to clean the old wall and pva it before going further. Not that anyone does it ).
For sure it would be better fixed if frame would be mechanically fixed to brick wall, and plasterboard fixed to a frame. Would be resistant to outside elements. But with thick brick wall, very low chance of that happening in my opinion.
Even if dot n dab loosens at few places over time, easy fix is to drill a small hole where it is loose and fill in with polyurethane foam adhesive with PU gun.
Thank you for all your replies.
I want to insulate the wall from inside, not insulate the external walls of the house.
What is the best thickness Recommended for ready insulated plasterboard? I would like the room to be really warm in the winter.
What would you recommend for good thickness and good quality insulation boards?
when we describe external walls,we mean window/external doors/non party walls pal not actually the outside of them
Could I ask what’s the budget?
I don't mind spending more money, if the plaster will last me for a long time and also if the insulation provided by the insulated plasterboard is very effective and keeps the room warm.
I don't work by budgets because I have never done this before and wouldn't have a clue as to how much this job would cost.
I don't might spending more money, if the plaster will last me for a long time and also if the insulation provided by the insulated plasterboard is very effective and keeps the room warm.
Thanks, I just completed a full upstairs and hall stair landing areas for a client , all in was £6500 which tbf is a good lump sum to pay out but the client had worked out his energy saving costs to get the pay back within 9 years on his total improvements, he also had boiler and windows done at extra by someone else
I’d advise check out energy saving trust website to see ball part figures of installation and cost savings once the works done ,
Why would you never dot and dab plasterboard onto an external wall with no cavity? I am assuming you are talking about an inside wall which is the main outside wall of the house.
I am looking for a local plasterer ( Mitcham, Sutton, Croydon) to do the following work -
- Internal wall adjoining the room shows lots of cracks. This wall to be meshed all over, covered with a joint compound then skimmed with thin layers of plaster.
- Ceiling crack taped, existing plasterboard secured to the joists with additional screws. Plasterboard on top, then skimmed.
- Internal wall adjoining the bathroom, repair the cracks, dB board acoustic plasterboard (not E board). Door Architrave refitted to accommodate the width of the plasterboard. New skirting board to be fitted afterwards.
- External wall with the window. This wall is damaged on the top right hand corner by the curtain track. Check the condition. It is also in a bad state under and along the bottom of the wall. Remove the cracked wall and take it back to brick, render than plaster/skim.
After the repair and once dried, dot and dab and fix few long screw for added strength, Gyproc Thermal Laminate PIR 53mm (Travis Perkins Code - 771973). This plasterboard would work well, as it has a vapour control layer, fire proof and is acoustic. The wall can then be skimmed with thin layers of plaster.
The insulation to be continued in the cupboard, along the same wall. I will try and remove the shelving inside the cupboard, so the insulated plasterboard can be stuck on as one long piece.
- Window ledge replaced to accommodate the wide insulated plasterboard and the skirting board removed and replaced with a new board after fitting the insulated plasterboard.
The plumber will move the radiator pipes forward once the insulated plaster board is up and skimmed.
- The area round the window to be fitted with narrower 25mm Thermal Laminate PIR insulated plasterboard. The window trim may or may not need removal.
- The electrician has added extra sockets, which can be fixed once all the plaster boarding and skimming is done.
Please contact me with a quote.
Thank you.
It would be nice to know what is your budget ? When people are booked 2 weeks or 2 months in advance, spending time to quote is also money. Someone will probably do it though.
Most people will try to see it first before quoting.
My guess would be that its best for you to have everything done, and ask for quote for someone to skim it.
Typically, yes. But the way you describe it, the scope of works, would require many stages, many repeat visits, where plasterer would do a few hours a day... So you are better of do it in stages, see how it goes. Presuming you can vacate that space while ongoing work.
you have a lot of things you need to consider for your project, which is great that you are taking the time to research and plan. Here are some answers to your questions:
  1. Difference between insulated plasterboard and wooden strip batons: Insulated plasterboard is a type of plasterboard with a layer of insulation material attached to it. It is a more straightforward option, as you simply attach the insulated plasterboard to the existing wall and plaster over it. Wooden strip batons require more work, as they need to be attached to the wall, and then insulation material needs to be added between the batons. The advantage of the wooden strip baton option is that it provides a cavity for the insulation, allowing you to add more insulation if needed.
  2. Fireproofing: Most insulated plasterboards are fireproof to a certain extent, but it is best to check with the manufacturer to see the exact specifications.
  3. Hanging heavy curtains: Hanging heavy curtains on a wall with insulated plasterboard should not be a problem, but you may need to use heavier-duty wall fixings to ensure the weight of the curtains does not pull the plasterboard away from the wall.
  4. Cost: The cost of your project will depend on the materials you use, the size of the room, and the amount of work required. It is best to get a quote from a plasterer or builder to get an accurate estimate.
  5. Recommendations for an electrician and plumber: For a qualified electrician and plumber, you can check with local trade organizations, such as the National Electrical Contractors Association (NECA) or the Plumbing-Heating-Cooling Contractors Association (PHCC), or ask for recommendations from friends or family.
Threads over 4 years old moonfruit
