Hey I need some advice on hard wall under plaster.
I am plastering on to old render, I have removed the old blown skim and primed the surface with Cemtone plaster primer. The old render is all over the place so I need to pull it out with an under coat.
I'm I right in thinking that because the background is of moderate suction I should use hard wall instead of bonding or does it not matter?
Any advice would be appreciated thanks
