hi m8,
i used them for years before the drills came out they are ideal for small walls ect its easy to make your own usually done with an old bike cog and a steel rod welded together, failing that as an ermergancy use a small Drain cover nailed to a small broom shank or similar, the ones u can buy range from ok to very femma, but they will do the job
