I have a workshop to dab using 40mm insulated boards and want to use secondary Fixings as its over existing render. Can I just use ewi fixings? All I can find specifically for plasterboard are twistfix galvanised fixings and I don't Particular like the look of Them.
It's just as quick to fix a roofing battern at top and bottom of wall and then fix board screws once the gear is off and some of the board manufactures it's a spec'd fixing method
Steve the galvanised twistfix are fine mate, ive used them on internal insulation before and had no come backs at all.
How do you actually fix it as its a smooth indented head isnt it?
