Grano topping v Weber duro range
mark ross
Gentlemen,,
I have about 700m2 of grano topping to lay and polish ....which we are well converse with.
I want to explore the posibility of using the Weber industrial system ( 4600, 4610 ) as a high impact equivelent.
Do any of you have any experience with this system, goood or bad.
mark
i use the weber products. am currently using a 4360 rapid drying base and 4160 RD top coat. i put it through a monojet with a d8 -1.5.
The duro screeds are part of their range. i have some coloured stone duro coming up.
never done grano
never done grano
How do find the 4160, I guess you need to spiky it at 5 to 6mm as per usual ??
Encon, ccf all the usual and it will be a direct delivery for the amount you need. Definitely prime the floor first with their primer. Spread it with a 5mm notched spatula on a stick then show it the spiky oys doys. Get yourself some of them spiky overshoes aswell so you can walk in the screed.
