Right lads, a retaining garden wall, I'm guessing water pressure from other side has blown off some k rend.
Would hp12 or weber lac go over the lot of it with mesh and then mushrooms every 400 suffice before top coating??
All ideas welcome [emoji106]
There isn't enough land drain at other side, it's our house, and I'm not keen on digging the whole bloody garden up!
Any 'stronger' ideas?
Might just do the above and hope for the best!
Re do it every couple of years lol
Can't you dig out behind the wall and get some sort of membrane down there?
That may be a ball ache to start but redoing it every few years would be worse!
I'd rather re do it once a month than dig that feckin lot out by hand! Surprised at what is coming through considering it's a 13 inch wall.
Is hp12 better than weber lac for this job? Or is it the same product by and large?
As Mikeatthis says,I would drill 1"1/2 core for pipe at bottom several times. It should release a bit of pressure as well, as it could push your wall over eventually
