G** P.L.A.Z.I.F.L.E.X!!!
zombie
I have absoloutley no idea why ive just done it but just walked out of merchants with 1 of them stupid 16" refina plaziflex thing!
Think I has an out of body experience or summet......
Sooooooo......
What the f**k do I do with it bar skip!!!!
ZOMBIE G** T.H.R.E.A.D
Tbf hardly use mine anymore. Good for a tidy up and polish. Put it on. Lay in same gear. Run over no pressure with plaziflex while it wet. Gets it close enough. Finish as normal.
Tbf I bought it in my head for these cold minging months to try and speed sets up.
Thinking should of bought a bigger 1 then if it's for a quick flatten?
ive laid in with em and not left a single line mate. Have a play about with it, don’t pull water up so is faster set
Been using my mt all the way through again for a while now. Got fed up sanding plastics down. Been using an ox ultraflex lately which is decent. Just don’t give a f**k how it dries anymore. Long as it’s flat smooth nice angles job done. Board n skim extension Thursday friday. Mt and ox.
Any bigger than 14’’ only good if background is flat. Take this lid, builder said a skim, homeowner said will that be flat & level...
I left them to debate the outcome :)
Been using my mt all the way through again for a while now. Got fed up sanding plastics down. Been using an ox ultraflex lately which is decent. Just don’t give a f**k how it dries anymore. Long as it’s flat smooth nice angles job done. Board n skim extension Thursday friday. Mt and ox. View attachment 42252
Nice I rate the ox there decent and cheap enough (y)
Sooooooo......
I use one all the time once u get used to it you will be hooked /AND IM NOT G** @lurpak is right in what he says about them
That's using a mt,then speedskim,mediflex then s*p*r*lex :LOL: drys nice if you hit timings right
Sooooooo......
