Flushing ritmo
ankers
Have any lads always used accelerator in the barrels for a long time and not had problems. Were doing over nights with fassa but soaking the next day so want to accelerate it? How is everyone flushing there machines out? Not sure if i should get the doser
Dansouthcoast84
i hook up a hose to the water inlet on front of machine
open all valves and let it run through for a couple minutes... but i do fill the soleniod tube few times aswell
Rigsby
TPF Special Forces
The doser is good and it will give you peace of mind. My Ritmo and water pump needed expensive repairs after using Wickes and not flushing out.
But I did continue using accelerator mainly an Irish one what didn’t ha the Chloride free additive in.
I took the pipe off the mixing chamber, wacked up the float to maximum and took out the mixing shaft then ran it for a couple of minutes on speed 10. Not had a problem for 4 years after the repair and I used Accelerator all year round except for overnighters.
loky11
I've seen some of the damage accelerators can cause with out using a dosser, I personally wont do it, not worth the repair bill.
ankers
Can you set it to minimum rigsby say if I only wanted to add a little if its fassa overnight. I only do next days but fassa hangs for ages
