johniosaif
The customer to be ?? Wants sand/cement and skim over this painted brickwork and plinth , they have sbr’d it before , would you ?
NoThe customer to be ?? Wants sand/cement and skim over this painted brickwork and plinth , they have sbr’d it before , would you ?View attachment 42347
Key surface with an angle grinder, go into your local Johnstone's decorator centre get a bag of key coat primer, give the wall a tight pass and key it then bang your sand and cement on
I told them to grind it or eml , but they’ve done one before and it’s fine ...Key surface with an angle grinder, go into your local Johnstone's decorator centre get a bag of key coat primer, give the wall a tight pass and key it then bang your sand and cement on
That stuff that I've mentioned is high polymer with fibres in it it's only 12 quid a bagI told them to grind it or eml , but they’ve done one before and it’s fine ...
Sticks like s*** to a blanket literallyThat stuff that I've mentioned is high polymer with fibres in it it's only 12 quid a bag
Yes only if it has rendaid on it 1st . This is over painted brick its stuck like fukThe customer to be ?? Wants sand/cement and skim over this painted brickwork and plinth , they have sbr’d it before , would you ?View attachment 42347
Can you do that as one coat ( monolithic) or wait a day ? Who sells parinther?i would use Parinter as a scratch coat. bed fibre mesh in if cracked. EML is a thing of the past.
Can you go over it straight away with render ?Parex Parinter renovation render. it is a base coat that can go straight on to painted surfaces.
customer was convinced it would be fine , I wasn’t , not at allSurely no matter what you prime it with the S&C will only be stuck to the paint? If so that seems like a bad idea to me? Scratch through with a grinder would me at least some contact with something solid enough to hold the S&C.
It's not like it's a lot of paint to grind away atSurely no matter what you prime it with the S&C will only be stuck to the paint? If so that seems like a bad idea to me? Scratch through with a grinder would me at least some contact with something solid enough to hold the S&C.
TrueIt's not like it's a lot of paint to grind away at
That's why I prefer mesh , washered screws for peace or mindSurely no matter what you prime it with the S&C will only be stuck to the paint? If so that seems like a bad idea to me? Scratch through with a grinder would me at least some contact with something solid enough to hold the S&C.
You are the pro
Tell customer you need to get a key to
Brickwork so will run grinder over it & seal so is more moneys
Get in get out get paid
I’d do what I think is right anyway as ever , just that she was so sure
Your welcome
Expensive though Malcolmlarry, have a look at the Parex Perinter web page. we have used this material for several years. it is used extensively in the renovation of lime and sand and cement render. labour saving.
Yes ex met all the way and stainless steel screwsThat's why I prefer mesh , washered screws for peace or mind
