Never ever!!!!!!!!!only fix exsternal out side with Galvanised nails or a 4:1 RENDER MIX.MUSH 9 said:Just ordered a load of (pvcu) external bead for two rendering jobs starting spring, the company recomends fixing these with "Addhesive mortar".
Would i get away with using Dab ?????
plastering tutor said:Never ever!!!!!!!!!only fix exsternal out side with Galvanised nails or a 4:1 RENDER MIX.MUSH 9 said:Just ordered a load of (pvcu) external bead for two rendering jobs starting spring, the company recomends fixing these with "Addhesive mortar".
The gypsum in the plaster will break down from damp conditions.
id use pink grip what company did you useMUSH 9 said:Just ordered a load of (pvcu) external bead for two rendering jobs starting spring, the company recomends fixing these with "Addhesive mortar".
