Fingers in the crack
mark ross
Sometimes...a silly piece of polypropylene mush just doesn't cut the mustard. 1870 s property sitting above a Victorian train tunnel. :RpS_crying:
so, helix and resin is the answer? easier than lintels which we used in the old days, ribbed lath screwed on top would help also.
weve just had a similar one,
we did as said above chased out the motar joints inserted 6mm bar and resined in
I knew a bird like you could get into like that .............she was known locally as carpark mandy...................she was a school boys dream................:RpS_thumbsup:
Summat not quite rite about that first pic Mark :RpS_unsure:
It's a Tunnel alrite :-0
i guess that a structural engineer would tell you to put a needle through the wall, remove the damaged brickwork, replace the lintel that has dropped, putting weight on the window frame, and rebuild the area in london stock bricks.
