Finally!
Go easy it was my first time!
Also the photos make some bits alot smoother than what they actually were.
  • Finally!
  • Finally!
  • Finally!
Been cloudy here all day once it's dry and the sun's on it ill get a photo and if it's more wavy than the north Sea I'll tell you I never got a chance to go back. To be fair they were nice sized easy panels. The only question I have is the guy who's job it was method is to scratch coat all the walls first to about 10 mm with the top coat and leave it to set. Is it ok doing it that way I don't remember ever seeing people describe doing it that way. Also he had put beads under all window cills, is that necessary?
Yeah he done the scratch coat a few days ago. He said when he was doing it it 2 passes the same day it was slumping too much and since he's been doing it that way he's not had an issue
I'm not sure why he would use mono to scratch with. When I first turned up I assumed it was a base coat. What method do you use? Just two passes same day?
On to block? any time I've used k rend or enewall (powerwall when i used it) we basecoated and put mesh in the base and topped another day 2 passes wet on wet Did you get scraping same day?
Yeah we had everything on that we wanted to by about 11 and started scraping back of 5/6ish. How thick is your base coat? We probably only put on about a 10mm coat
