Feb 2 in 1 bottle
Jimbo95
There’s a feb 2 in 1 bottle both waterproofer and plasticiser. I heard your meant to put waterproofer in scratch coat and plasticiser in top coat. This 2 in 1 should be alright for both coats right?
smoother09
Depending on the time of year this is my go to especially in the hotter months!
smoother09
I could put hundreds of pics up and you wouldn't be able to argue with the quality my customers have orgasms over the work I produce that's all that matters!
smoother09
Work after work recommendation after recommendation it's so bad my phone stays on silent and I pick through the voicemails! :coffe:
essexandy
The Lake Governor
No not all waterproofers have plasticiser in Andy is that better!
Not all, but unfortunately most do nowadays.
The Cementone one is good gear. I particularly like the Everbuild 3 in 1. The retarder in it helps get moisture back into the gear on the wall in hot weather. I only use it in the backing coat though.
bobski
I like freeflo, decent gear.
I find everbuild 3 in 1 is good, it dries harder too.
Doesn't seem to introduce TOO much air into the mix.
Also it's one of the multi purpose ones that's a salt inhibitor too, so that you can use for damp work aswell.
It's higher regarded that their actual waterproofer.
